closed
tosgamer
I've had it for about 6 months and it has worked without issue, just upgrading to a 5900x. The previous owner was the one that lapped it and it looks like he put a couple of distinctive scratches near the center, probably to identify the chip. I will be using those scratches and the numbers on the pcb to identify the chip as well. Do not expect the temps shown in the 4th pic unless you undervolt using AMD Curve Optimizer. 5800x cpus do run hot out of the box. Buyer should have good Heat. My Heat
Thanks all
