Closed: Xeon E5-1650v4
Status
Not open for further replies.
Bromeister
Selling E5-1650v4 as i bought a v3 (from lyang238 here) to overclock and no longer need the v4. Purchased in July, stress tested, light usage since.
$525 shipped Sold to a bro for $450
heatware is Bromeister.
Imgur: The most awesome images on the Internet
H100i v2 (same as h100i GTX) BNIB sealed from RMA. $75 shipped CONUS
SOLD on /r/hardwareswap for $70 shipped
you OC'd this? with what? and to what speeds?
also in the body of your fs post, op, there's a typo: you list it as a 1640v4
Yeah it's locked so all you can do is run a minor base clock. I tried 103 and change and it would boot but had instability. It was stable at 101 or 102 I don't remember which. Not really worth the effort for the 100mhz gains I was just scratching an itch.
Wait, is the 1650 v4 locked? I thought all the Xeon 1600's were unlocked chips? That might throw a wrench in my upgrade plans.
Yup I was under the same impression, figured it out the hard way. I ended up buying a used v3 and now I have to sell the v4. V3s are still available new and are a good $50 cheaper than the v4s, if you want to go that route. Or you could just say screw it and buy a used v4 ;)
Status
