RaphaelVinceti
- Apr 7, 2005
I've been thinking about building a Closed system to eliminate dust, im just not quite sure how i should go about doing it. I was thinking i would get a passive radiator (probably a large aqua and mount it to the case), and leaving it on the outside of the case, with the barbs/tubing runing into the case through custom holes w/rubber to prevent cutting the tubing. But im curious about something, if im going to be doing what, should i WC EVERYTHING in the system, including Ram, HDDs and the Northbridge? or will i be safe just watercooling the CPU and GPUs? Im not planning on overclocking with this system, I just want to leave it on constantly, and im extremely perceptive to noise, so if i leave on a system with fans in my room, i cant sleep at night. Anyone have any other suggestions for me?
Thanks
Oh.. and Case suggestions would be nice too.
Thanks
