Dennis Gordon
- Sep 13, 2005
I have 3 15K SCSI drives in may machine (dual booting XP Pro/XP 64 bit). I recently cloned my 36G C, boot drive to a Fujitsu drive of the same size that is faster and quieter. I used Acronis Migrate Easy. Worked great. My XP64 bit install is on E, which is an 18G Seagate. Very fast drive, but I just picked up a 36G Maxtor Atlas II, and I was thinking of cloning my 64 bit OS to it.
I know you can clone a drive to a larger drive, but do I need to partition the larger drive if it's a system disk? I could just mess around with Acronis, I suppose, but I thought I'd ask here first.
Also, as long as I'm juggling drives around... I was following the thread about moving the page file to another drive. My questions are: given the speed of these SCSI drives, is there any performance gain to be had by such a move, and must it be moved to a separate physical drive rather than a partition? This is a newspaper graphics workstation. Thanks for any help....
3800X2 @ 2.54
1G DDR 400 @ 422
NVS280 Quadro 64 meg
3x 15K U320 HD
3800X2 @ 2.54
1G DDR 400 @ 422
3x 15K U320 HD
