Hi
I've a Seagate hard disk divided into 5 partitions: C, D, J, K, and H. C and D are primary partitions with C as the system drive hosting Windows XP.
I'd like to clone partitions C, D, and J only to a new, larger sized WD Caviar Black drive, and replace my old Seagate with the WD. Ideally, the end result is that the cloned C, D and J partitions will be identical in size to the existing ones, with a large unformatted section on the WD drive.
What would you recommend as the most straightforward procedure to accomplish the above objective using free software tools? I've spent some time reading about DriveImage XML, BartPE and a few tools but none seems to offer the selective cloning feature. Further, there appears to be frequent problems with how to set the OS partition of the new drive active.
Thanks!
Max
Thanks!
Max
