I just installed a new Raid 0 array of 2x SATA 36.7GB Raptors. My current HD setup is this:
Primary IDE Master: WD 250 GB, 125GB partition 1 system, 125 gb partition 2 storage
Primary IDE Slave: WD 120 GB, 120 GB partition 1 storage
What I want to do is clone the 125GB system partition one onto the SATA Raid 0 array. The array is seen in windows as a logical drive, and it is bootable because I originally installed windows xp on it and it was working fine, but I didn't want to reinstall everything so I formated it and opted to go the clone route.
I'm following the instructions in this thread:
http://www.hardforum.com/showthread.php?s=&threadid=728914
However, my problem is this, when I use True Image 7 for a HD clone, it clones the entire HD, not just the system partition, so obviously that wont work (system partition is about 45gb full, storage partition is completely full, so its trying to put ~160 gb on 74 gb). Therefore, I had to use the image route. What I did was make an image of my C: drive, then restore it onto the raid 0 array. I then shut down the computer, unplugged my regular IDE drives, and attempted to boot up from the array. I got all the way to the blue windowsxp screen, but before the login names slide in, the computer completely freezes.
Does anyone know what is wrong / have any suggestions?
Thanks,
Kevin
Thanks,
Kevin
