Clone Existing XP Machine - Run In Mac OS
rosco
How would you guys recommend cloning an existing Windows XP machine and running it on a MAC?
I know there are several programs out there to run windows on a mac but I want to run a clone of the existing windows machine. It has a couple software programs that are a real pain to setup.
Thanks.
If your XP machine is a physical machine, you'd have to do some research and focus on Parallels, Fusion and Virtual box, and see what VM format they can import. Then you can download VMWare's free converter, run it on your XP physical machine and then import it to the software program of your choice to run on a Mac.
