clone display with different resolutions
mimoawi
i have Radeon X1800XT, sony FW900 CRT and NEC 1970NXp,i m trying to set different resolution for each monitor but CCC wont allow me it only works with NEC max resolution which is 1280x1024,is there any way to do that?
thanks
When you are cloning the display, they will have to be the same resolution. (thus the clone, same thing on both displays, thus they must have the same number of pixels) If you set it to extending the desktop you should be able to run different resolutions.. but then it wouldn't be cloned would it?
UltraMon
Greatest monitor program ive ever used..
I think itll work for you.. Bit like LAzn said.. If you clone and have different resolutions, your not actually cloning.. But give Ultramon a shot
