Clone 3 monitors on HD 6950?
Trackr
I have 3 monitors attached to an HD 6950:
1.) DVI
2.) HDMI
3.) Mini-DP (Active)-to-HDMI
I can fashion them into one giant display with Eyefinity..
But what I really want is to clone all of them, so that they're all technically my "Main Monitor".
How do I do this?
AFAIK you cant clone 3. Maximum is 2. I don't know if its a windows limitation or an AMD limitation, but on my 7970s i cant clone to 3.
You mean in CCC? Yes, I know. I was thinking maybe there was some third-party software that could force it. I've tried DisplayFusion and UltraMon because people recommended them, but I couldn't get them to clone 3 either.
1.) DVI
2.) HDMI
How do I do this?
I've done it by accident several times when Eyefinity screwed up with my HD6950's. Make sure you set CCC to Advanced Mode to access the settings.
I've donw this. Go to ccc and creating ans arranging deskfops. Hit duplicate on each of the monitors and you're golden
Right Click on Desktop
Left Click on Catalyst Control Center
Left Click on Creating and Arranging Desktops
Left Click on the Arrows next too a monitor and disable it. - Do this for all but one display.
Then Left Click on the Arrows next to the disabled monitors and hit Duplicate.
Then you're done.
You can try Hitting Windows Key+P then put it in computer only mode to disable all but one monitor (this is monitor 1) before trying to duplicate the monitors. Duplicate is how you get back to eyefinity.
