Wesley1357
- Jul 4, 2005
does the clock speed on ati x850 series get clock down if it is too hot? how do i stop that, can anyone help?
Wesley1357 said:gtx is twice faster than my x850xtpe
tsuehpsyde said:Sounds like a driver problem? Uninstall the drivers, reboot into safe mode and use driver cleaner to remove all traces of it, reboot into windows...download the latest drivers and install those, then reboot again (all just to be 'safe'). Then run the benchmark and see what you come up with.
I had to do that tonight because 3DMark05 was magically losing 1,000 marks on my new GTX, and even after fixing the bus speed it was still acting retarded...so after doing a completely clean and proper driver uninstall/install, problem was solved.
