Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I wanted to start off using clockgen to OC my Q9300 a lil bit, but apparently it's not working on Vista 64 bit. Has anyone used clockgen on vista 64? Or are there any other programs that allows you to oc through windows?
Word of advice - never have a program overclock automatically for you. If you want to overclock in Windows check out SetFSB - http://www13.plala.or.jp/setfsb/
