clockgen?
captain204mike
i have a DFI CFX3200 MOBO
when i try to do overclocking and load clockgen and click on the i think it is PLL Control or something, it doesnt have the sliders, guess it doesnt auto pick up the info from the board,
so i select one and it only has one slider, and looks like it is changing everything when i move the slider like the pci etc....
anyone know what setting i have to select in the setting so it works with the motherboard the right way?
I am not sure if the mobo is supported my clockgen. Either way use your bios to change you clock speeds
so i need to change my cpu speed and then bootup and test restart change etc...
nice,, that will take a long time
any other programs that will do it
Overclocking isn't really for people who are in a hurry.. easy way to blow up your stuff...
Take your time and don't forget to stability test... (and you thought changing the bios settings took a while ;) )
