clip on mic
I have that mic - it is fine, not spectacular but good enough to do the job
ok, thanks. I'm wondering if I should try to find a wireless one, since I've already have earbud wires.
This is my 2nd one. First one lasted maybe 4 years. I tend to roll over cords in my chair a lot so that is pretty good lifespan for me.
Greta mic, cheap worth it.
I have this as well. It's cheap and does the job. You don't exactly need some high quality mic just for communicating in games.
I only wish the clip was tighter, because my earphones use thinner cords.
cool, i'll order it tomorrow unless theres a wireless option for around the same price.
One thing I should mention is because of where you will probably need to place it (further away from your mouth), combined with the sensitivity and bare bones nature of it (no built in noise cancelling) it will pick up more background noise than a boom mic right by your mouth or something with noise cancelling.
ok, I'll be using push to talk, my environment is fairly quiet.
I have that mic, it never worked. Maybe I'm doing something wrong but I tried everything. I think it's faulty.
excellent mic, i usually clip it on my shirt, everybody can hear me loud and clear without having to mess with the default settings, (except the usual scrubs that prefer to game with speakers :rolleyes: )i have bought 3 :D
