Clip for CMOS battery snapped off...
n64man120
I was just working with an old mobo I'm using to build an HTPC and when i lifted the CMOS battery clip lever, of course the old worn metal snapped and now I have no clip to hold the battery in. Any suggestions? I'm thinking just a little Scotch tape and hopefully it'll hold the battery in place :rolleyes:
How good are you with a soldering iron?
Find a dead mobo with the same socket...pull it off and put it on yours.
Pull the battery out first. They explode if they get hot enough.
Hot glue around the sides. It's clear, it will come off with no remnants, and if you do a good job you'll never be able to tell.
Ya try some hot glue. That stuff will hold up well enough and still come off easily later if you want it to.
u guys know how to hot glue spring metal together, AND have it conduct electricity?
that, i gotta see. :rolleyes:
the spring on top has no need to conduct electricity
as long as the system is on its side and the battery just sits there, it works perfectly normal.
on a side note, i'm getting the board rma'ed for free due to blown capacitors although the board is 7 years old. Think they'll complain about the busted battery holder?
