Clearance with video card
Black-Falcon
Do any of you guys know if it is possible to put swiftechs BGA Video Memory sinks on a 6800GT that has an MCW-55 on it (With barbs) without clearance issues?
While I can't say for certain, the MCW-55 has pretty good clearence. It cleared my OCZ sinks on my 7800GT without any problems.
no, they are too tall =[. google search the item # and it will give you a review where they had to cut them almost in half. Still, they have good performance, but for the non-hassle and price i would just go with the ocz sinks. my 2 cents.
efey`
the swiftech ones are decent. I had to trim the one under the hose coming in (very easy to do). Get so thermal epoxy though, they don't stick for nadda
