Oct 26, 2007 #1 M mark660 Limp Gawd Joined Apr 21, 2007 Messages 510 hey guys im modding a wester digital 80gb sata 2 drive with a clear top im just wandering wat material i should use for the clear top?
Oct 27, 2007 #2 O OmegaAvenger 2[H]4U Joined Sep 25, 2007 Messages 3,240 Lexan (or something similar) is what I Think WD uses for their raptor X series hard drives. They feature a window on top.
Oct 27, 2007 #3 Susquehannock Supreme [H]ardness Joined Jul 26, 2005 Messages 5,025 Lexan (polycarbonate) or Acrylic should work.
Oct 27, 2007 #5 M mark660 Limp Gawd Joined Apr 21, 2007 Messages 510 thanks guys will post pics when its finished
Oct 28, 2007 #6 M Michael Daly [H]ard|Gawd Joined Jan 6, 2007 Messages 1,212 Are you assuming this drive will function when you're done? Unless you have a cleanroom to work in, don't get your hopes up.
Oct 28, 2007 #7 M mark660 Limp Gawd Joined Apr 21, 2007 Messages 510 i have a dead wester digital drive so im gana mod the top of the dead drive then transfer it onto a good drive and i will find a clean spot
Oct 29, 2007 #8 M Michael Daly [H]ard|Gawd Joined Jan 6, 2007 Messages 1,212 mark660 said: i will find a clean spot Click to expand... Not clean spot - cleanroom. Dust you can't see will trash the drive.
Oct 29, 2007 #9 R Rabid Badger 2[H]4U Joined Mar 9, 2006 Messages 2,093 I know of two other people on the forums that have done a mod like this successfully, one quite recently. The best place to install the new cover is in a thoroughly cleaned bathroom with a hairnet, surgical mask and safety glasses. Here's a link to one of the threads: http://hardforum.com/showthread.php?t=1231730&highlight=hard+drive+window
