Clear, right side panel.
Westwood
Got a new build in the works. My current system sits in a cabinet on the floor. With the new build, I plan on getting out of the enclosed space; my kiddo is now opening doors to everything, and the new system I'm sure will run a bit hotter. So I plan on making a shelf up on the wall for the PC to sit. But, the wall is on my left. Is there a case that has everything mounted on the left side with the right side clear? I'm toying with the idea of water cooled so it'd be neat to see it. Also wouldn't mind having a side fan for airflow either.
Worst case scenario I just get something with solid on both sides. Not sure what wording I should use for my search. "clear right side pc case"?
Thanks.
I did a Google search for "PC case with window on the right":
Modular case that allows you to move things around:
https://www.thermaltake.com/products-model.aspx?id=C_00002559
Another candidate:
https://www.corsair.com/us/en/Categories/Products/Cases/Carbide-Series™-Clear-600C-Inverse-ATX-Full-Tower-Case/p/CC-9011079-WW
And another:
https://www.bequiet.com/en/case/1472
All of those options were in the Reddit thread I stumbled upon using the above search term.
Good luck!
I found some of the same things. I didn't know if there was a specific term to use since there wasn't much coming up.
"Reverse ATX" I guess is the phrase too. Not seeing much however.
