bigdogchris
- Feb 19, 2008
I built my new system about 3 months ago and hid my wires pretty well by drilling a hole in the back side of the 5 1/2 bays to run wires. I also ran the fan wires behind the mobo tray and out a hole in the bottom of the tray to come up and plug into the mobo. I'm not happy with the way I had to cobble it and now I want a clear side panel. But it worked well except for one thing.
1. The cpu power connector comes off the psu and realy just has to roll up becuase it plugs in right underneath the PSU, no where to hide it. I noticed in cases with the PSU on the bottom you have to run the wire up so you can hide it.
What I'm looking for is a black case, w/ lear panel, capable of supporting 8800gts (length wise), so probably would need a full tower. Also, obviously a case that has pre-made holes to run wires behind the mobo tray to hide all the wires. I can't find anything on newegg. I'm looking to spend anywhere from 0-150 ish.
Anything off the top of your head?
Thanks!!
Thanks!!
