Clear ntbackup catalog
Ezekial
I am using 2003 Server and I want to clear the catalog file in my ntbackup. I found an MS article, but I do not have the folder it specifies.
%SystemRoot%\Documents and Settings\Account\Local Settings\Application Data\Microsoft\Windows NT\NTBackup\catalogs
http://support.microsoft.com/default.aspx?scid=KB;EN-US;325832
So I am not sure where to look at next... haven't had enough luck yet on Googling to find an answer for me.
The catalog is within the program and is a catalog of the backup that has ran. It has accumulate over the last year or so and I don't want to manually right click each one and choose delete.
Heading home from work now... check in when I get there... and do some more looking if necessary.
Thanks
Are you replacing the word "Account" with the name of the account you are using to run the backups?
yes :D
:edit
I only have one account on there to boot, "admin", but went ahead and checked the other folders as well.. even though I knew it should not be there... "default user", etc.
%SystemRoot%\Documents and Settings\All Users\Application Data\Microsoft\Windows NT\NTBackup\
Insane thread necro but it came up in a search and didn't have the answer so had to look elsewhere...
