Clear console gaming with TV Wonder Pro
Neoaether
Is there any way to get nice clear resolution with composite cable for my PS2? I want to be able to hook my ps2 to my puter for gaming action, but its blurry as all hell.
I have done this before. I do not remember having any problem with picture quality but you WILL run into another problem once all is set up correctly.
The computer adds a little bit of lag time to the picture..... This means that if you are playing a game like Madden (for example) the football would already be past the receiver by the time it shows up on your monitor. Does that make sense?
There was like a 1/8th second delay when I hooked mine up and it drove me nuts. I ended up picking up a HDTV adapter for my monitor and play games on my computer screen through that.
No...the tv displays from video cards are akin to using non-native low resolutions on LCD
monitors...and there's that lag from processing video.
Your best bet is to get a vga adapter for the PS2, or you may want to try one of those
pass through boxes that lets you use your monitor as a TV, enabling use of any composite
or S-video signal.
I used one a long time ago on a crt for viewing vcr/tv on my computer screen, it was great
functionally wise, but the overall I.Q. was shot. But none the less it was still cool to press
a button and watch tv while my pc downloaded pr0n in the background... :)
