clear 92mm fan?
Shadey216
hey guys. I bought the Thermalright slk-947u for a system i'm building, and next up i need to buy the fan for it. I was looking to get a 92mm fan for it, i reeeeally like the way this fan looks from SVC: http://www.svc.com/crquuvledfan2.html but unfortunitly i can't find a 92mm that has a look like this. Soooo my plan is to buy a clear 92mm fan and some UV reactive plastic dye and make one of my own. But I can't find a clear 92mm fan anywhere. Does anyone know a place that sells a clear 92mm fan? I can't find any
*Edit* Ugh found one actually, heh thanks anywase
