Cleaning the inside of your computer?
deadman_uk
I know some of you don't clean the inside of your PC but I do because after a few months, it is covered in dust, raising the temperature which can't be good.
I know a can of compressed air is perfect for the job but these are expensive and run out quickly. I need a better alternative that will last much longer and cost a lot less in the long run.
I know you can use a vacuum cleaner but I heard this is a bad idea because it can produce static that may damage your components. I must admit, I have used a vacuum cleaner a few times and I have had no problems but what else is there to try? Is there a vacuum cleaner that can work like a can of compressed air?
Air Compressor works great, just dont have the psi cranked, I would stay way from a vancum cleaner, could break something easily. In the past when i worked for computer shop's we just used a Air Compressor.
I use a vacuum cleaner but make sure you don't touch anything. Nothing bad has happened to me yet. *doesn't knock on wood*
ditto on the air compressor. i have one of those ultra compact compressor/flashlight/beacon emergency car things that I use. easy to carry around, about the right amount of power, etc... or just set the vaccuum to reverse so it blows air?
Company called Datavac used to make an electric duster. I picked mine up at a Micro Center a few years ago for about $50. I'm glad I picked one up because it saves a lot of $$ in canned air if no air compressor is available. Here is a sample
