Cleaning Storm
Just wash those out with distilled, and the copper bits with vinegar. Make sure to clean the jets on the baseplate.
Should be able to fit a pin through the jets if need be. Be careful, though, as acetal is fairly soft, and will "fluff" away if you end up picking at it too much.
Be careful with the vinegar though. When I cleaned my Storm before the first install I used vinegar as instructed by some other sites and the copper must have reacted with the vinegar because I got some kind of corrosion in the copper. I had to clean it off with an abrasive pad, really ticked me off.
