Cleaning shiny/oily keyboard/mouse
rgratto2
I searched on this but couldnt find anything that great, everyone wanted to disassemble things, but thats not my issue. What my problem is is that several of my keyboard keys and certain parts of my mouse are shiny and kind of oily, Especially my alt key. How do i go about cleaning this? I tried isopropyl alcohol wipes, and those dont really do That much. I know how to take keys off the keyboard if need be, but i dont know what to do to clean these suckers. Its kinda gross.
Thanks.
When some keys get shiny, it's usually from wear so cleaning won't help. I saw a fair share of shiny keys from keyboards taken out of workplace pc.
Hmm. Well i havent had this for too long...although i guess i do use it a lot. Any place to get replacement keys?
What keyboard ? Try the manufacturer but it's often cheaper to get a new keyboard.
If it's a lighted Logitech, they are built that way and it's not oil.
well, its a logitech mx duo, which are not in production anymore. So....i dont think replacement is really a great idea. I dont think its grease or anything from the manufacturing either, its just from using it. Same thing happened with my old one...
yeah i think you wear the texture down on it after a while and make the keys smooth....
buy a new keyboard... i bought a generic $5 keyboard on newegg once... one of the best keyboards ive had... although ive since replaced it with a logitec since it was damaged in a move
Myself, I stock on IBM keyboards from work since they use a different one due to linguistic requirements in the government. Each time I wear one, I give to my son for some destruction bliss :D
I know what you're talking about. It's not oil.
It's just the plastic has worn so smooth it looks like it.
Kinda like the interior plastics used on Korean Cars in the 1980's/early 90's. Yuk!
-Larry
Thanks.
I used some lyscol stuff that says "Cuts grease" on it. It helped a decent amount. Not fully but.....a bit. Saw this somewhere:
"Simple cleaning for pen and finger marks or grease can be taken care of with 409 or Simple Green or Agent Orange sprayed on a cloth or paper towel and then rubbed on the board, followed by a clean water wipe (wetting towel first!) and a dry towel. Don't spray directly if you can help it. "
