Apr 19, 2011 #1 H HaX [H]ard|Gawd Joined Dec 17, 2005 Messages 1,916 I'm thinking about buying an air compressor for cleaning my computers and airing tires.. now would a 2-3 gallon compressor work well for this? I really dont want a huge air compressor cause i'll moving it around a bit.
Apr 19, 2011 #2 D drescherjm [H]F Junkie Joined Nov 19, 2008 Messages 14,933 Yes this will be fine. Make sure you drain the compressor between usage to prevent the chance of moisture building up inside.
Apr 19, 2011 #3 T tonytnnt Gawd Joined Jun 30, 2004 Messages 871 You could probably get something even smaller than that. And +1 to draining them.
