Cleaning Question
magoo
I am changing MBs and will empty out my loop.
I should clean out the Apogee GTX since the loop has been in operation for about a year.
What should I clean the inside of the block with??? Hot water?? Alcohol?? Bleach ???
I have a Micro-Res as well, should that be cleansed??? Like-wise the radiator???
I plan on replacing the tubing.
