Over time, copper watercooling components build up tarnish when left exposed to air. Unfortunately this tarnish also develops inside the component.
What would be the best way to remove this tarnish? I can't open up the radiator...
I'm planning on using a vinegar+salt solution in the loop to flush out all the tarnish.
Would there be any problems in running a diluted vinegar+salt solution in a loop? Am I forgetting any unwanted chemical reactions which would occur?
