- Oct 29, 2000
Hey all,
After some research on this subject, I just cleaned the first of my two radiators (an Alphacool Monsta 280).
I did it by boiling distilled water in a kettle, pouring it in to the radiator, letting it sit for a few seconds, then pouring some out, shaking, pouring some more out, shaking some more, and repeating until it was empty.
I poured the water out through a coffee filter, and then reheated the same process 10 times.
Results:
Only one little fragment came out of the radiator, and I don't think it's flux.
I actually don't think it's from the inside of the radiator at all. I think it's a little black paint coming off from the threads in the port.
I also cleaned my Alphacool XT45 420mm, and it too was very clean. In this one we can see some tiny flux fragments, but nothing like some other users have posted from other brands.
No paint chipping from the port threads on the XT45 though.
My conclusion is that the inside of these Alphacool radiators must be very clean from the factory, but I am a little concerned about the paint coming off around the port. I'm guessing the threads weren't supposed to have any paint on them, and some inadvertently got in there, and now it's coming off. Either way, it shouldn't be an issue though, because once my fittings go on there, it should be covered, and none should wind up in the loop. I'm also not concerned about leaks around the ports, because the fittings have rubber seals.
I'd appreciate any input though.
How about the rest of my parts? Do I really need to clean the blocks? They look pretty good. Should I rinse out the inside of the tubing just in case? Appreciate any input.
--Matt
Results:
--Matt
