I need to clean some old water cooling parts that have been in the same loop for nearly two years. I'll be removing and replacing the tubing, and taking apart the blocks to clean them. Most of the gear is Danger Den, with the GPU blocks being NV78 models and the CPU block being a TDX. I also have a Danger Den Bayres, and I'm unsure of the pump or rad type.
Now I was looking for guides on how to do this, and came across this guide here. It just so happens I have a large amount of Hydrogen Peroxide. What I'm curious about is will the Hydrogen Peroxide damage the copper or acrylic used in these water blocks. I'm thinking about causing the copper to oxidize and the acrylic to crystallize.
Thanks as usual guys.
