Cleaning my loop
XSKSTEVEXX
I posted on here about a week ago regarding all this gunky build up inside my loop. I was using Fluidxp at the time, since then I have ordered some pentosin and I have already removed the fluidxp.
Is it safe to run a vinegar/water mix through the loop to try to flush this crap out?
Will it hurt the pump at all?
Use vinegar on ONLY copper pieces. Vinegar will attack plastics and stainless steel alloys.
Straight tap water is good for flushing. Run the entire loop with tap water for a few minutes, then drain it all. Then run a good few minutes with DISTILLED water. Drain that, then add the new coolant :)
