Got a Velocity-micro branded Lian-li case a week ago, and it's got some sticky-residue on two spots.
How would I go about getting that off, without damaging the anodized aluminum?
I would prefer a "tested and tried"... but if not, I could test it on the bottom of the case.
Also, is it easy enough to remove the velocity-micro branding from the case, to replace with my own? It's on the silver bar that goes across the top/mid/bottom, and I'm not sure what material it is.
