Alvein said:I don't have a blower. How can I remove a thin layer of dust that covers the MoBo, video card, etc.? Is it safe to use a soft brush? Are video and memory so delicate?
10x![]()
Maybe you shouldn't use a 60 psi compressor to blow air across your system....c1001 said:just remember to hold the fan blade (CPU, VGA, case fan, chipset, etc) with a finger when you blow compressed air on it to keep it from spinning. You can break the fan by it spinning too fast. I've done it.
DeepFreeze said:Maybe you shouldn't use a 60 psi compressor to blow air across your system....![]()
defakto said:Do not use an air compressor either, Canned air is actually a chemical that compressed is a liquid and goes to gas when you release pressure on it. It also has no water content. Using an air compressor could in theory put small droplets of water on the board(I've never had an air compressor that didn't push a little bit of water out of it when used.)
