Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i got my first dell 17in lcd... so nice and bright, i dunno the model...
but its fucking sick..
since this is my first lcd, i dunno how to clean it. how do i clean the screen?
i dont want to kill it..
i paid over $300 for it
thankz
To clean your antistatic screen, lightly dampen a soft, clean cloth with water. If possible, use a special screen-cleaning tissue or solution suitable for the antistatic coating.
To clean your Midnight Gray monitor cabinet, avoid using detergent of any kind. Detergent leaves a milky film on plastics; particularly the darker colored ones. It is best to use a lightly dampened warm cloth to clean the cabinet.
White powder substance, due to shipping, may appear on the plastic or near bezel edge. If you observe this, simply wipe it off.
Darker color plastics may scratch and shows white scuff marks more than lighter-colored monitor. Handle your Midnight Gray monitor with care.
*** Do not use benzene, thinner, ammonia, abrasive cleaners, or compressed air.
