Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My VP171b has lots of little dirt spots lots of streaks and such all over it. I've tried cleaning it using a glasses-cleaning cloth but that doesn't get anything off. So what should I use?
I use Kensington Screen Guardian. It works great for all monitors, LCD or CRT and doesnt leave any streaks. Its dirt cheap too. As for cloths, I use the Kensington Surface Guardian. They also work well and are cheap.
