I use a Shuttle XP17 LCD. Now, it has a glass cover over the actual LCD. What I am wondering is if I can use something like Windex or endust to clean off the glass?
Does the glass have an anti-glare coating on it? If not you can use just about anything. From a chemical standpoint glass is really f'n tough. Acetone, gasoline, lighter fluid, hydrochloric acid, Draino, whatever. Plain glass takes serious chemicals to damage. Don't get it on the paint or plastic case parts though.
If it has a coating or you're not sure, I'd error on the side of caution. I normally use an old cotton sock with a hole in it (ie- a soft cloth) and water to clean my CRTs. If they need more than a little soaking in water and light rubbing I'll use Windex.
