Cleaning annodized aluminum?
PS-RagE
How do you guys get fingerprints, etc off your aluminum? I'm finishing up a project I've been working on forever and it is covered in fingerprints that don't seem to want to come off
I have an aluminum case and i ran into the same issue you did, after moding the case there were finger prints all over the case, i found that using goo-gone in the spray bottle works really well not only does it clean the prints its actually shines up the case. Make sure you buy the goo-gone spray gel, and then just spray some onto a 100% terry cloth towel and wipe the case down, after that take another towel and wipe any remaining residue off the case. Tell me how it goes.
You should be able to find the spray at any major grocery store, home depot or on the web.
