Cleaning aluminum
JamesL
I have some sticky residue on my black lian-li case. Would it be safe to use 90% isopropyl alcohol on it? Has anyone tried it?
I used isopropyl alcohol to clean sticky residue off of my lian li case and afterward I used WD-40 to shine it up. Do like a test spot inside the case to see if there any problems. I bought mine used and with a little help with WD-40 mine look like new again :D.
WD-40, really, wow...thanks for that info. I was wondering how I could clean the fingerprint marks off my A05B. :D
Then you will have a greasy surface and dust will collect and make mud. Not a good idea especially if its inside the case.
Yeah, I used the alcohol yesterday..
Took that baby off like no one's business.
True, but if you wipe off really good it's shouldn't be greasy and still leave shinny surface.
