AVAFREAK182
- Jun 10, 2007
Is it dangerous to take it apart?
Am I ok to just disassemble it and clean it with some isopropyl?
What are you cleaning from the PSU? You should just use compressed air and blow it out. No need to disassemble it (which would also void the warranty).
If you smoke, you should at least avoid doing it near your PC.I smoke (yes...I need to stop) & I have to clean my rig every two months to rid of dust etc. I purchase a decent amount of of canned air & it does do the job.
