Cleaning a CRT
Xaero
I have a Viewsonic P70f, and i was just wondering what I should clean it with because i don't know if the Ammonia in Windex is okay for the glass and whatever they put on it.
jamestime88 said:
windex = no win
just dampen a soft cloth with water and wipe the monitor.
yep this is the only way.. and to finish it off. Get newspaper (no not a joke) and wipe it after with that. This takes off most of the streaks and lint at the same time :)
Old window washer trick hehe
I take 2 wads of toilet paper (tissue paper can have weird lotions, etc), damp one with water, go up/down/side/side motions. Then take the dry "wad" and go from up to down and repeat, going over each area once. This always works great. Make sure its dry by going over again with another wad...if the water air drys spots can appear. Good as new, and cheap. I wouldn't use newspaper, who knows what those inks could do to the antistatic coating
BTW I own j00 in quake 3 w/railgun
