Cleaning a case
Bdonedge
What do you guys use to clean your case and not damage the material or hardware inside? I'm trying to remove finger prints
I generally used Compressed Air for the dust. Any left over dust, dirt or hard to remove stuff I use alcohol pads/swabs.
Same here, with the addition of Q-Tips to reach those tight corners and fan edges.
Is this including the exterior? I have 91% alcohol, I was thinking about using on the outside of the case to remove those nasty finger prints.
First I go over the chassis with a swiffer duster pad. Then blow out the crevices with air, then dust again with pad.
