Cleanest Case/Heater Core/Rad Setup
davewolfs
Hello everyone,
I have been doing a lot of reading on setting up my first water cooling system and I think I have a pretty good idea of most of the parts that I will need. From what I have read, heater cores are the way to go if they will fit in your case.
That being said ideally I would like to have an acrylic case where I can easily mount a radiator that has 2x120mm fans attached to it I really don’t want to have to buy a case that I will have to completely customize myself. Danger den seems to have some cases that fit this description, but they are really limited in space.
Hopefully someone else could make a recommendation, I understand that Koolance also has some cases but they are way over priced in my opinion.
Thanks,
Dave
i can show you what NOT to do ;)
I am now convinced that everything you own is made out of wood, even the computer parts; you just paint them really well.
"Clean" and "Acrylic Case" are oxymorons. There is no such thing as a clean setup in an acrylic case...because there is nowhere to hide all the miscellaneous bits and pieces that you need to hide in a computer setup.
If you want some ideas for clean water cooling, I think you still cant beat Liquid_Cooled's Setup .
If you absolutely must get an acrylic case you should ignore a clean watercooling setup as that will be the least of your worries.
