- looking for a very smooth, and clean case with inverted motherboard design. (optional)
- has to be less than $100.(w/ or w/o PSU)
- light( my current xaser3 is a pain to move!)
-mid-tower
mostly I want it very clean with a clean front. It will be used for modding and I will cut a rectangular hole on the front from the bottom to the cd drives. the floppy is going to be mounted vertically on the left side bottom of the case. A hole for a 120 mm fan in the center (btx style) it will be used as a design element. The side can't have a window because im going to cut a custom one.
case is for my fiance... she is really into native american stuff and the center fan is going to have a dreamcatcher covering it. the side is going to have a cut out silloutte of a wolf with mesh and blue and purple backlighting.
thanks!
-mid-tower
thanks!
