skiermatt2
- Nov 29, 2003
I am trying to set up clark connect to monitor network traffic but cannot get it to work. All I want to be able to do is use the bandwidth monitor and merely have all the traffic pass through the box. All IP's on the network (individual pc's) are statically assigned and should remain so. NAT does not need to be used. Should my default gateway on my LAN interface be the IP of the WAN interface and the gateway of the WAN interface be the standard network gateway (assigned by the campus network admins)? Should the default gateway on the hosts be the LAN interface of the clark connect box? The setup of the network is users -> switch -> router(clark connect) -> switch(managed by the university) -> campus network. Thanks in advance for your help.
