nitrobass24
[H]ard|DCer of the Month - December 2009
- Apr 7, 2006
I have a 5505 at home that i am using. Just got VPN configured for IPSEC so i can connect in, using my iphone.
What i would like to do is use Remote Potato over VPN.
I have it setup and working, when i am on the wireless internally; however, when i go to 3G and VPN i can connect to the server, browse files, but it will not start playing. Would i need to open any ports even though i have connected via VPN?
EDIT: Problem 2, I need to Tunnel-All, so how can i configure NAT for my VPN ip pool to redirect web traffic back out the outside interface?
I have attached my current config.
Code:
: Saved
ASA Version 8.4(1)
hostname ciscoasa
domain-name davis.local
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_192.168.2.0_24
subnet 192.168.2.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool iphone 192.168.2.1-192.168.2.255 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.2.0_24 NETWORK_OBJ_192.168.2.0_24
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca server
cdp-url http://ciscoasa.davis.com/+CSCOCA+/asa_ca.crl
publish-crl inside 80
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
vpn-addr-assign local reuse-delay 5
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy iphone internal
group-policy iphone attributes
dns-server value 192.168.1.5
vpn-tunnel-protocol ikev1
default-domain value davis.local
username stephen nopassword privilege 0
username stephen attributes
vpn-group-policy iphone
tunnel-group iphone type remote-access
tunnel-group iphone general-attributes
address-pool iphone
default-group-policy iphone
tunnel-group iphone ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:e09ada06bd5c0cc37a0773d6ab040d5a
: end
