Jaffa Cakes!
- Oct 13, 2007
Hi guys,
Moving our crappy old NEC phone system to something new very soon and looking for some help...
My requirements are x2 PSTN lines (we're UK based), 6 IP phone extensions, a power failure phone, voicemail for these extensions, and a menu (1 to go to a voicemail box, 2 to go to reception, 3 for IT sort of thing).
Anyone got any ideas on hardware, modules, and which IOS version I need? Config isn't a problem, I've never had to purchase the hardware or licensing before though.
If we go router based I'd like to still use it as a router for NAT etc, but we don't push much internet traffic (8mbps ish). If you think Cisco isn't necessarily the answer please do recommend something else! Our budget is going to be a few thousand.
Many thanks
Many thanks
