Carlosinfl
Loves the juice
- Sep 25, 2002
I've got a server that is timing out and is very slow. When I view the port on the switch that the server's plugged into, I see that the port has many errors / collisions. I also noticed it's running at half duplex as well:
My server, switch, and Firewall all have Gigabit connections so I wanted to know if you guys recommend I manually configure this interface to run at Full Duplex of should I leave it alone?
Code:
GigabitEthernet0/11 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.54c6.ee0b (bia 001b.54c6.ee0b)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
[B][COLOR="Yellow"]Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX[/COLOR][/B]
input flow-control is off, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1331911
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 81000 bits/sec, 39 packets/sec
5 minute output rate 509000 bits/sec, 50 packets/sec
667083406 packets input, 54365047130 bytes, 0 no buffer
Received 428 broadcasts (0 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
896036917 packets output, 564804192781 bytes, 0 underruns
0 output errors, [B][COLOR="Yellow"]20511126 collisions[/COLOR][/B], 1 interface resets
0 babbles, 30531440 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
