what are you wanting to use it for? Firewall and/or VPN concentrator? Both devices are EOL by the way. I would be hesitant to use either in a business environment.
Posted via [H] Mobile Device
A PIX 506e is ghastly-old...
I'd opt for anything over that.
Yes. You can only run up to 6.3 on the old PIX. At least you can run a 12.4T IOS release with the firewall feature set on the 1711. They are kind of pokey though by modern standards.
That 506 only has 10Mb ethernet ports if that tells you anything. Personally, I like to use firewalls for firewalls and routers for routing. The PIX is going to be easier to get VPN working IMO.
I think you're talking about the old (they're both old, but one is oldER, lol) 506, the 506E has 100m interfaces.
I think difficulty will be relative. I find it easier to get anything working in IOS vs the PIX/ASA OS. I work with IOS a lot more though, so naturally it's easier and I prefer it. It really depends on the person and their experience, IMO.
The Cisco PIX 506E is a robust, purpose-built security appliance that delivers enterprise-class security for remote and branch office environments.
The compact desktop chassis of the Cisco PIX 506E provides two autosensing Fast Ethernet (10/100) interfaces. Ideal for securing high-speed Internet connections, the Cisco PIX 506E delivers up to 100 Mbps of firewall throughput, 16 Mbps of Triple Data Encryption Standard (3DES) VPN throughput, and 30 Mbps of Advanced Encryption Standard-128 (AES) VPN throughput in a cost-effective, high-performance solution.
Guess I'll keep looking on Ebay for a used Cisco Pix 506e.
Meh, you'll want something like a PIX 515e if you want to go that route. Unless you want to learn a whole new command structure that is completely obsolete now that is only used by devices that are EOL. You can't run a remotely modern version of the PIX OS on a 506e, it's not supported. Get something a little less crappy or you'll be kicking yourself later.
Is Cisco PIX 515e needed even though its for my father's home so he can connect while he is away?
Thanks,
Brian
You'll be able to set it up as a quasi-concentrator for the Cisco IPSEC VPN client, but not the new AnyConnect client (which requires licensing anyway). That Cisco client does not run on 64-bit Windows without emulation. Just something for you to think about.Looking for Firewall and one Remote VPN User access.
