Carlosinfl
Loves the juice
- Sep 25, 2002
I have an older Cisco 2600 series router than was power cycled and now for some reason gets an error while booting:
I don't know what caused it but for some reason this machine is not booting. It loads to the 'rommon 1' prompt and from there I have tried changing the config register first to 0x2102. After I rebooted, it still didn't boot from flash. I then tired the following:
After I rebooted the router, it made no difference. Anyone know what I can do to get this thing back working?
Code:
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
Code:
rommon 2 > confreg
Configuration Summary
enabled are:
load rom after netboot fails
console baud: 9600
boot: the ROM Monitor
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
disable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[0]: 2
enabled are:
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C2600
do you wish to change the configuration? y/n [n]: n
You must reset or power cycle for new config to take effect
