Hey,
So I'm playing around with a Cisco 2651xm router I obtained.
Got it up and running for normal traffic via DHCP, but having some issues with port forwarding. Seem to work in the sense that traffic is hitting the internal IP but will not establish an RDP session.
Here is the config:
1.
sh ip int br
Interface IP-Address OK? Method Status Protocol
FastEthernet0/0 67.81.xxx.xxx YES DHCP up up
FastEthernet0/1 10.0.0.1 YES NVRAM up up
2. partial
sh run
ip dhcp excluded-address 10.0.0.2 10.0.0.100
ip dhcp pool Wired
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 4.2.2.1 4.2.2.2
ip name-server 4.2.2.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip dns server
no ip http server
no ip http secure-server
ip nat inside source list NATlist interface FastEthernet0/0 overload
ip nat inside source static tcp 10.0.0.50 3389 interface FastEthernet0/0 3389
ip access-list standard NATlist
permit 10.0.0.0 0.0.0.255
Try to establish RDP sesion from an external machine and it seems to try to get in but wont establish. Side question - what is up with the UDP on the first line below??? Do I need to add a line with something like 'ip forward-protocol' ?
I also tried creating an access list for the RDP access but no success there either...
3.
sh ip nat trans
Pro Inside global Inside local Outside local Outside global
udp 67.81.xxx.xxx:137 10.0.0.50:137 10.255.255.255:137 10.255.255.255:137
tcp 67.81.xxx.xxx:3389 10.0.0.50:3389 209.94.xxx.xxx:3293 209.94.xxx.xxx:3293
tcp 67.81.xxx.xxx:3389 10.0.0.50:3389 --- ---
Any ideas would be appreciated! Playing around with this router at home to get more familiar with IOS.
Here is the config:
1.
sh ip int br
2. partial
sh run
ip dhcp pool Wired
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip dns server
no ip http server
3.
sh ip nat trans
