Ok, I am setting up a new plant for one of my customers, I have all the cable drops done, have everything patched down and cables tied into the main switch, everything is wired and setup. The only thing I lack for completion of this job is getting their internet connection setup. They were sent a Cisco 851W router, I have never had to setup a Cisco router from scratch before. I am using the SDM manager and it looks like everything is setup.
I can ping the gateway from both the router and any computer on the network. I can not ping the ISP's DNS servers or any other IP address. Here is the funny thing though, I can plug the modem directly into the network card on the server, setup the static IP settings on the card, and it works flawlessly, so the problem is not with the internet connection.
I am stumped, I have tried countless changes yesterday and today is a freakin Saturday, been up here for 3 hours already trying to figure this out with no luck. I am hoping to get them online today so I can bill them for my time but I just can't figure this out. I have another Cisco router(not even close to the same model) that I am referencing it's config file and everything looks almost the same, I just don't get it!
Here is the network info:
192.168.0.x subnet
mask 255.255.255.0
router ip 192.168.0.251
ISP's DNS servers are 208.6.232.10 and 208.6.232.12
Here is the running-config from the router, I have blanked out the WAN IP address and encrypted passwords for obvious reason, please help!
192.168.0.x subnet
mask 255.255.255.0
Code:
Building configuration...
Current configuration : 4680 bytes
! Last configuration change at 11:52:45 Chicago Sat Jan 27 2007 by admin
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ****
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 ****
no aaa new-model
resource policy
clock timezone Chicago -6
clock summer-time Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.159
ip dhcp excluded-address 192.168.0.171 192.168.0.254
ip dhcp pool sdm-pool1
network 192.168.0.0 255.255.255.0
dns-server 208.6.232.10 208.6.232.12
default-router 192.168.0.251
ip cef
ip tcp synwait-time 10
no ip bootp server
ip name-server 208.6.232.10
ip name-server 208.6.232.12
ip ssh time-out 60
ip ssh authentication-retries 2
crypto ****
crypto pki certificate chain TP-self-signed-1910476874
certificate self-signed 01
quit
username admin privilege 15 secret 5 ****
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address WANIP 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
ssid ****
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.0.251 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface FastEthernet4 overload
logging trap debugging
access-list 100 remark SDM_ACL Category=2
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
